Creating a hybrid cluster starting from a DaaS cluster
  • A DataMiner cluster consisting of DaaS nodes only, which meet the following requirements:
    • Deployed in a region close to where your self-managed nodes are deployed to minimize latency.
    • Using DataMiner 10.5.0 [CU2]/10.5.5 or higher.
  • One or more on-premises servers ready to host DataMiner Agents (see DataMiner Compute Requirements).
  • An established site-to-site VPN connection between DaaS and the on-premises network (see About the site-to-site VPN connection).
  • Network address ranges that do not overlap. If the on-premises network overlaps with the default DaaS address space (172.23.0.0/16), first contact daas@dataminer.services to change the DaaS address space.
  • A user account with the Admin or Owner role in the dataminer.services organization that owns the DaaS nodes.
  • A dataminer.services organization key that has the Create DataMiner System permissions. For more information on how you can add a new organization key to your organization on dataminer.services, see Managing dataminer.services keys.
Step-by-step procedure
  1. Install DataMiner on the on-premises servers, using either the DataMiner Installer or the pre-installed DataMiner VHD, but do not run the configuration tool.
  2. On the newly installed Agents, set the following content in C:\Skyline DataMiner\DB.xml:
    <?xml version="1.0"?>
    <DataBases xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.skyline.be/config/db">
        <DataBase active="true" local="true" search="true" cloud="true" type="CloudStorage"/>
    </DataBases>
  3. On each of the newly installed Agents, create a file userInfo.json in the C:\Skyline DataMiner root folder with the following contents:
       "organizationApiKey": "ORGANIZATION_API_KEY",
       "dmsName": "DMS_NAME",
       "dmsUrl": "DMS_URL",
       "dmsOwnerEmail": "DMS_OWNER_EMAIL",
       "dmsExists": true
  4. Replace the placeholders with the appropriate values:
    • ORGANIZATION_API_KEY: An organization key that has the necessary permissions to add DataMiner Systems in your organization.
    • DMS_NAME: The DMS name of the current DaaS system you want to add the on-premises Agent to. You can find the name on https://dataminer.services or https://admin.dataminer.services. For example, hybrid-dms.
    • DMS_URL: The first part of the URL, i.e., the part before the dash, of your DaaS system. You can find the URL on https://dataminer.services or https://admin.dataminer.services. For example, if the DMS URL is https://hybriddms-myorg.on.dataminer.services, fill in the URL value hybriddms.
    • DMS_OWNER_EMAIL: The email address of the current owner of the DaaS system.
  5. Start up DataMiner.
  6. Upgrade the new Agents to the same DataMiner version as the DaaS nodes.
    If the DaaS cluster is running a version lower than 10.6.0/10.6.1, and you used an installer that does not include BrokerGateway (i.e. the v10.4 or v10.5 installer), you will also need to migrate to BrokerGateway because DaaS uses BrokerGateway by default.
  7. Enable Swarming on the new Agents.
  8. In DataMiner, create a new user account HybridAdmin and configure it as follows:
    • Assign it to the built-in Administrators group.
    • Make sure Password never expires is selected.
    • Make sure the password meets the complexity requirements of DaaS nodes:
      • It does not contain the user's account name or parts of the user's full name that exceed two consecutive characters
      • It is at least six characters in length
      • It contains characters from three of the following four categories:
        • English uppercase characters (A through Z)
        • English lowercase characters (a through z)
        • Base 10 digits (0 through 9)
        • Non-alphabetic characters (for example, !, $, #, %)
    The HybridAdmin user account will be used for cluster syncing, which means it needs to have the same password on all Agents in the cluster.
  9. Add the connection string URI towards the DaaS node, using the HybridAdmin user account:
    2. In the Advanced menu, select Edit Connection Uris.
    3. Right-click in the pop-up window and select Add New Destination.
    4. Configure the following fields and click OK:
      • To: Provide the IP address of the DaaS node. If you do not know the IP address, contact daas@dataminer.services to request this information.
      • Username: HybridAdmin
      • Password: The password you have created.
    5. Click Done
  10. Contact daas@dataminer.services with a request to add the on-premises system to the DaaS DMS.
    Make sure your email includes the following information:
    • The IP address of the DMA.
    • The password of the HybridAdmin user account.
    Skyline's DaaS team will perform the following steps on the DaaS Agents to add the connection string URI towards the on-prem nodes and add the new self-managed nodes to the cluster using SLNetClientTest tool:
    The steps below can only be executed by Skyline and are included here for reference.
    1. On a DaaS node, create a new user account HybridAdmin, and configure it as follows:
      • Use the password received from the owner of the on-premises node.
    2. Connect to the DaaS node using the SLNetClientTest tool.
    3. Go to the Advanced menu and select Edit Connection Uris.
    4. Right-click and select Add New Destination.
    5. Configure the following fields and click OK:
      • To: Provide the IP of the on-prem node.
      • Update All Connections To This Agent: Make sure this is selected.
      • Password: Specify the password you received.
    6. Click Done
    7. Go to the Build Message tab of the main window of the SLNetCLientTest tool.
    8. In the Message Type dropdown list, select SetDmsClusterMessage.
    9. If the cluster currently consists of a single DaaS node, set ClusterName to your desired cluster name, and click Send Message.
      Skip this step if the DaaS node is already part of a cluster with several nodes.
    10. In the Message Type dropdown list, select AddIPToClusterMessage.
    11. Set IP to the IP address of the self-managed node you want to add, and click Send Message.
    12. Once the setup is fully functional, to improve security:
      1. Log in to Cube with the HybridAdmin user account and ensure that the user account that was initially used to install DataMiner is added to the Administrators group again.
        When the clustering process finished, that original account lost access, but the user will need it to be able to access their DataMiner System like before.
      2. Update the connection string so it uses the DataMinerAdmin account instead of the HybridAdmin account
        This DataMinerAdmin account is entirely managed by Skyline, and its password must never be shared outside the Skyline organization.
      3. Either remove the HybridAdmin user account or change its password.
