Installing Cost & Billing
Before installing the solution, make sure the following requirements are met:
Installing the Cost & Billing Solution
To install the solution, after the prerequisites are met, deploy the Cost & Billing package from the Catalog.
This will deploy the following components:
  • The Cost & Billing low-code app.
  • The DOM model and automation scripts.
  • The Cost & Billing Dev Pack, which includes the Standard Data Model and provides typed read/write access to the Cost & Billing DOM instances.
After the package is installed, you can start configuring value units, contracts, and rate cards.
Installing the MediaOps sample integration
If the sample integration with MediaOps Plan is required, DataMiner 10.6.4 or higher must be installed.
In addition, the following components are required:
  • The MediaOps Plan package, version 1.6.0 or higher.
  • The Cost & Billing MediaOps Plan Adapter and Calculation, which provides the integration between MediaOps Plan and Cost & Billing. This package includes:
    • MediaOps Adapter: Synchronizes MediaOps data into Cost & Billing by mapping resources and pools to items, jobs to billable events, and workflows to groups.
    • MediaOps Calculation Script: Performs the time-based cost and billing calculations required for the MediaOps integration.
These components are only needed for the MediaOps Plan integration. For an integration with any other external system, a dedicated adapter and calculation script must be created. For details, refer to Integration with other solutions.
