Silent actions
Multiple "silent actions" are possible in scripts, allowing the scripts to interact with bookings without any user interaction. This section lists the most common use cases. Adjusting bookings in ways that are not described here is not supported and could have a severe impact on the stability of SRM. However, if a specific feature you need is not described here, you can submit a feature request to Skyline Communications to evaluate whether this could be added.
Since Feature release 2.0.1 of the SRM framework, the SRM Dev Pack is available, which allows you to easily add the required dependencies to develop these scripts. For details on how to install the NuGet on new or existing scripts, see SRM scripting using the SRM Dev Pack.
